Bypassing wireless security on a Cisco AP for a single device
May 21, 2008 3 Replies
Jump to replies (3)
I have a Cisco 1200 AP that uses WPA-Enterpise, TKIP, and PEAP to authenticate user laptops, using the user's Windows account and password. Now I have someone who wants to add a wireless video projector to the network. The projector can use the authentication method listed, but either a user account would have to be added to Active Directory, or an existing user account would have to be utilized.
I'm wondering if there is a way to bypass authentication for specific MAC address the projector uses.
you would probably want to create another ssid and use other vlan strictly for equipment (projectors, printers etc...). don't broadcast the name of the new wlan in the beacon, and use mac filter with open or wpa/preshared key as authentication method.
Using MAC addresses as access credential for wireless access is generally a bad idea. They can be easily spoofed. SSID broadcast doesn't make wireless LAN invisible. Anybody slightly interested in finding it will be able to do so.
Since projector can use PEAP, best method would be to create special user account for it.
Regards, Andrey.
Thanks. Both answers sound like they should work.
