Buffer errors (misses)
Mar 21, 2007 1 Replies
Hi all,
I've got some buffer errors on an 1811 - how serious is this?
Thank you!
Buffer elements: 1117 in free list (500 max allowed) 9750624 hits, 0 misses, 1119 created
Public buffer pools: Small buffers, 104 bytes (total 50, permanent 50, peak 1003 @ 4d10h): 47 in free list (20 min, 150 max allowed) 3183318 hits, 856 misses, 1363 trims, 1363 created 0 failures (0 no memory) Middle buffers, 600 bytes (total 93, permanent 25, peak 227 @ 1d20h): 22 in free list (10 min, 150 max allowed) 1995380 hits, 991 misses, 1071 trims, 1139 created 317 failures (0 no memory) Big buffers, 1536 bytes (total 50, permanent 50, peak 89 @ 1d20h): 50 in free list (5 min, 150 max allowed) 1037254 hits, 52 misses, 78 trims, 78 created 22 failures (0 no memory) VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 1d20h): 10 in free list (0 min, 100 max allowed) 16 hits, 6 misses, 1 trims, 1 created 6 failures (0 no memory) Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 1d20h): 1 in free list (0 min, 10 max allowed) 0 hits, 6 misses, 16 trims, 17 created 6 failures (0 no memory) Huge buffers, 18024 bytes (total 1, permanent 0, peak 1 @ 1d20h): 1 in free list (0 min, 4 max allowed) 0 hits, 6 misses, 16 trims, 17 created 6 failures (0 no memory)
Interface buffer pools: Async1 buffers, 1500 bytes (total 10, permanent 10): 0 in free list (0 min, 10 max allowed) 10 hits, 0 fallbacks 10 max cache size, 5 in cache 174 hits in cache, 0 misses in cache Dot11Radio0Psp buffers, 1680 bytes (total 80, permanent 80): 80 in free list (0 min, 80 max allowed) 28998 hits, 0 fallbacks Dot11Radio1Psp buffers, 1680 bytes (total 80, permanent 80): 80 in free list (0 min, 80 max allowed) 0 hits, 0 fallbacks SEC Eng Packet buffers, 1700 bytes (total 256, permanent 256): 0 in free list (0 min, 256 max allowed) 256 hits, 0 fallbacks 256 max cache size, 256 in cache 0 hits in cache, 0 misses in cache Dot11Radio0 buffers, 2400 bytes (total 96, permanent 96): 32 in free list (0 min, 96 max allowed) 3166578 hits, 0 fallbacks Dot11Radio1 buffers, 2400 bytes (total 96, permanent 96): 32 in free list (0 min, 96 max allowed) 64 hits, 0 fallbacks
Header pools: Header buffers, 0 bytes (total 384, permanent 384): 0 in free list (0 min, 512 max allowed) 384 hits, 0 misses, 0 trims, 0 created 0 failures (0 no memory) 384 max cache size, 384 in cache 4779774 hits in cache, 0 misses in cache Dot11Radio0 buffers, 0 bytes (total 300, permanent 300): 150 in free list (0 min, 300 max allowed) 150 hits, 0 misses 150 max cache size, 150 in cache 0 hits in cache, 0 misses in cache Dot11Radio1 buffers, 0 bytes (total 300, permanent 300): 150 in free list (0 min, 300 max allowed) 150 hits, 0 misses 150 max cache size, 150 in cache 0 hits in cache, 0 misses in cache
Particle Clones: 1024 clones, 1680 hits, 0 misses
Public particle pools: F/S buffers, 256 bytes (total 384, permanent 384): 128 in free list (128 min, 1024 max allowed) 256 hits, 0 misses, 0 trims, 0 created 0 failures (0 no memory) 256 max cache size, 256 in cache 1680 hits in cache, 0 misses in cache Normal buffers, 1676 bytes (total 512, permanent 512): 384 in free list (128 min, 1024 max allowed) 460 hits, 21 misses, 63 trims, 63 created 0 failures (0 no memory) 128 max cache size, 128 in cache 0 hits in cache, 0 misses in cache
Private particle pools: SEC Eng Particle Header buffers, 256 bytes (total 256, permanent 256): 0 in free list (0 min, 256 max allowed) 256 hits, 0 fallbacks 256 max cache size, 256 in cache 0 hits in cache, 0 misses in cache FastEthernet0 buffers, 1664 bytes (total 384, permanent 384): 0 in free list (0 min, 384 max allowed) 384 hits, 0 fallbacks 384 max cache size, 256 in cache 14283301 hits in cache, 0 misses in cache FastEthernet1 buffers, 1664 bytes (total 384, permanent 384): 0 in free list (0 min, 384 max allowed) 384 hits, 0 fallbacks 384 max cache size, 256 in cache 14950188 hits in cache, 0 misses in cache FastEthernet2 buffers, 1676 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 128 hits, 0 fallbacks 128 max cache size, 64 in cache 17675415 hits in cache, 33 misses in cache SEC Eng Particle buffers, 1700 bytes (total 256, permanent 256): 0 in free list (0 min, 256 max allowed) 256 hits, 0 misses 256 max cache size, 256 in cache 2499055 hits in cache, 0 misses in cache
Buffer misses happen by design. They are nothing to worry about.
As far as I know the "Public buffer pools: " section is the only part you can do anything with.
However - a large proportion of misses on a heavily loaded router will I feel affect the performance and I manually adjust buffers to reduce to reasonable levels.
Failures are not so good and more or less indicate a packet drop. You will usually see corresponding increments in interface drops/ignores/throttles.
In your case I may consider increasing the buff middle min-free a bit if I had some memory free.
Your miss/failure counters are low.
