BGP - Transitive / Route-Map What am I missing.
May 23, 2005 4 Replies
Jump to replies (4)
I am working with BGP in a lab and I am missing something that I clearly don't understand.
The lab is as follows - one site (AS1234) connected to two providers (7018,209).
Again this is in a lab so please do not mind the private addresses or any of the other fictious info I use.
I am using the following route-map to control outbound routing updates
access-list 10 permit 10.10.10.0 0.0.0.255 access-list 15 permit 20.20.20.0 0.0.0.255
! route-map AS-7018-OUTGOING permit 10 match ip address 10 set as-path prepend 12345 ! route-map AS-7018-OUTGOING permit 20 match ip address 15 set community 7018:20
!Route map is applied... router bgp 12345 neighbor 50.0.1.1 route-map AS-7018-OUTGOING out
My understanding is that only the two IP blocks would be sent outbound and not the other routes learned by my IBGP neighbor. However in my lab when I do
sh ip bgp nei advertised-routes
I see that I am advertising all of the partials I received from the other provider through my IBGP connection. What am I missing? I thought that if none of the conditions were met on the route-map that the route would be silently discarded and not redistributed.
Amy.
snipped-for-privacy@paxemail.com wrote in news:1116856172.138041.101520 @g49g2000cwa.googlegroups.com:
Try add the following to your route-map:
route-map AS-7018-OUTGOING permit 30 !
Remember that in case the prefix you wish to export do no comply to your route-map, the prefix is not adverticed. Therefore you'll need a "permit all" in the end of your route-map.
Cheers Lars Christensen
I may not have communicated it correctly - but I am seeing the networks I want to be advertised through BGP advertised to my EBGP peer. In addition I am seeing networks that are not matched in my route map also be advertised.
Amy.
But you're only setting the prepend, community. Are those not being set?
I am not sure what is going on now? I went back and looked and it appears as if the route map is only advertising what I want it to. It's possible I forgot to "clear ip bgp soft out" to update what I am advertising.
Just to be sure
This route map should only advertise the two networks listed in the above access list correct?
Amy.,
Hansang Bae wrote:
providers
outbound
