begginer question
Apr 19, 2005 5 Replies
Jump to replies (5)
Hello I'm starting work with Cisco devices. I have 1700 model. Please, could someone tell me how I can backup Cisco configuration on HDD. I have no additional tools
Thanks for help
What you need is a tftp server (you can download one for free) then you copy the config to the tftp server with the comand "copy start tftp" from enable mode.
I am fairly new to Cisco too - I am preparing for my CCNA as we speak. Regarding this issue, TFTP runs on UDP right? If I try to use the Cisco TFTP server and between my PC (running the TFTP software) there is a PIX firewall with NAT I cannot seem to do copy the config files accross the NAT network (of course I can use the rollover cable and do it locally) but is there a way to bypass this?
The error I am getting is:
%Error opening tftp://IPADDRESS/configfilenane (Undefined error)
Thanks in advance for all help.
J
Yes, TFTP uses UDP port 69...gotta love it.
Perhaps if you posted the PIX's config we would have something on which to base our troubleshooting...
I agree, the PIX is probably blocking it. But it could be other things, or ACL's in other places.. But its a good place to start. Are you sure you have started the TFTP first? Sound funny but that happens..
The cheap way is to do a 'sh run' and copy and paste the output to a text file.
Chris.
