asdm group error PIX 7.1
Oct 31, 2006 0 Replies
hi; sorry for repost, but I need to fix this and can't get any further:
Cisco PIX Security Appliance Software Version 7.1(2) Device Manager Version 5.1(2)
my user has privilege level 4, if I connect via ASDM (or via java/browser)to the pix, I get the following output:
### "this may be the first time that ASDM has been used with this unit. ASDM must update the topology database by sending ASDM specific commands to the pix unit..."
"these commands provide PIX with the location of hosts or networks on each interface...."
no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 asdm group OG_net_INTERN dmz reference OG_net_INTERN1 ###
[why would it send the same command 8 times and then add the group that was removed ?]
if I click: "send" , my output is:
### OK] no asdm group OG_net_INTERN vmz reference OG_net_INTERN1 [ERROR] no asdm group OG_net_INTERN dmz reference OG_net_INTERN1 Specified 'asdm group' does not exist
[OK] asdm group OG_net_INTERN dmz reference OG_net_INTERN1
### then all I can do is click "cancel", and the following pops up:
### "you have cancelled sending commands to pix.this will limit asdm functionality.now you will NOT be able to access the configuration view in the gui." ###
then I have read-only access to pix vie ASDM.
any ideas what could cause this problem?
thanks, M
