Citrix through Web VPN
Jun 25, 2006 2 Replies
Hi All, I have setup a 1841 Router with WebVPN, behind a 837 internet router. I have natted through port 443.
I have a Citrix server inside and am publishing it through the WebVpn.
I can connect to the Web Interface but can not launch applications. If I use the activeX component I get a generic error, can not connect to an application. If I use the Java client I get an error "Error opening ICa file" "The address of an application server must be specified"
I have internally created certificates installed on the router and the root certificate installed as trusted in IE and Java.
There is an error logging on the 1841 each time I try to launch an application.
Jun 22 05:02:08.246: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x63A24534
-Process= "SSLVPN_PROCESS", ipl=
0, pid= 120 -Traceback= 0x60AD545C 0x61180F74 0x6117E9B8 0x61BBD2C4
0x61BBAB20 0x61BBB104 0x61BBEDD8 0x61 BCDA0C
Here is the running config without the real names or IPs.
Thanks for any suggestons. I have spent ages on this so far.
----------------------------- bob#s run Building configuration...
Current configuration : 8679 bytes ! ! Last configuration change at 15:03:08 NZST Thu Jun 22 2006 ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname bob ! boot-start-marker boot-end-marker ! no logging buffered ! aaa new-model ! ! aaa authentication login default local aaa authentication login sdm_vpn_xauth_ml_1 local aaa authorization exec default local ! aaa session-id common ! resource policy ! clock timezone NZST 12 clock summer-time NZDT recurring 1 Sun Oct 2:00 last Sun Mar 2:00 ip cef ! ! ! ! ip domain name mytestwebvpn4.co.nz ip name-server 10.73.220.4 ! ! crypto pki trustpoint TP-self-signed-117527664 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-117527664 revocation-check none rsakeypair TP-self-signed-117527664 ! crypto pki trustpoint mytestwebvpn4.org.nz enrollment terminal serial-number fqdn bob.mytestwebvpn4.co.nz ip-address FastEthernet0/0 password subject-name OU=MY_OU, CN=bob.mytestwebvpn4.co.nz, C=NZ revocation-check crl rsakeypair SDM-RSAKey-1150934803000 ! ! crypto pki certificate chain TP-self-signed-117527664 certificate self-signed 01 D8AC05A8 6B2F9945 3E quit crypto pki certificate chain mytestwebvpn4.org.nz certificate 61C2A6A000000000000F
8C4E7AB quit certificate ca 2F2FAD22B439B28F4BDB0CF2978A5E85 DDEBC0 99175B8C FCD38DF6 E586759C
6C5FA52A B3F7DF quit
! ! interface FastEthernet0/0 ip address 192.168.193.222 255.255.255.0 duplex auto speed auto ! interface FastEthernet0/1 ip address 10.73.220.248 255.255.255.0 duplex auto speed auto ! ip route 0.0.0.0 0.0.0.0 192.168.193.1 ! ! ip http server ip http secure-server ! access-list 101 remark Outside access list inbound traffic access-list 101 permit tcp any host 192.168.193.222 eq 443 access-list 101 deny ip any any log ! ! ! ! scheduler allocate 20000 1000 ! webvpn gateway sample_1 ip address 192.168.193.222 port 443 ssl trustpoint mytestwebvpn4.org.nz inservice ! webvpn context Default_context ssl authenticate verify all ! no inservice ! ! webvpn context test_1 title "Test Web VPN" title-color #669999 secondary-color white text-color black ssl authenticate verify all ! url-list "Printer" heading "HTTP Printer" url-text "HP Printer" url-value "http://10.73.220.38"! url-list "SDMCitrixServerList2" heading "My Citrix farm" url-text "server2" url-value "http://10.73.220.71/Citrix/MetaFrame/auth/login.aspx"! login-message "You must be authorised to access this network." ! policy group NUTS01_RDP url-list "Printer" url-list "SDMCitrixServerList2" hide-url-bar citrix enabled default-group-policy NUTS01_RDP aaa authentication list default gateway sample_1 inservice ! end
bob#
Here are the lines in my ACL I had to add inorder to get citrix working through our PIX. May help you out it may not. the hostname csg was our citrix gateway and the hostname citrix was our citrix server on the inside network.
access-list dmz2inside permit tcp host csg host Citrix eq www access-list dmz2inside permit tcp host csg host Citrix eq 8081 access-list dmz2inside permit tcp host csg host Citrix eq https access-list dmz2inside permit tcp host csg host Citrix eq citrix-ica access-list dmz2inside permit tcp host csg host Citrix eq 3389
Steve
Scotty wrote:
HI Steve, Thanks for your input.
However it seems that you are using a Citrix Secure Gateway, where as I want to use the Router's WebVPN to connect to the Citrix farm
As far as I am aware I only need to open up 443. I am seeing no access denies on the outside interface so it does not appear to be using any other ports.
Regards, Scott
