ASA and SSH
Mar 20, 2009 1 Replies
I'm trying to get SSH to work on the ASA from a remote location, i've creayed the SSH key etc... but still no joy, can anyone point me in the right direction?
: Saved : Written by enable_15 at 06:06:56.398 UTC Thu Mar 19 2009 ! ASA Version 7.2(4) ! hostname xxxx domain-name default.domain.invalid enable password E4uBcGsdaUuWMrXz encrypted passwd 2KFQnbNIdI.2KYOU encrypted names ! interface Vlan1 =A0nameif inside =A0security-level 100 =A0ip address 10.xx.xx.xx 255.255.255.0 ! interface Vlan2 =A0nameif outside =A0security-level 0 =A0ip address 83.xxx.xxx.142 255.255.255.252 ! interface Vlan3 =A0shutdown =A0no forward interface Vlan1 =A0nameif dmz =A0security-level 50 =A0ip address 192.168.64.10 255.255.255.0 ! interface Ethernet0/0 =A0switchport access vlan 2 ! interface Ethernet0/1 ! interface Ethernet0/2 ! interface Ethernet0/3 ! interface Ethernet0/4 ! interface Ethernet0/5 ! interface Ethernet0/6 ! interface Ethernet0/7 =A0switchport access vlan 3 ! ftp mode passive dns server-group DefaultDNS =A0domain-name default.domain.invalid access-list nonat extended permit ip 10.xxx.xxx.0 255.255.255.0
10.xxx.xxx.0 255.255.255.0 access-list nonat extended permit ip 10.xxxx.xxx.0 255.255.255.0
172.31.254.0 255.255.255.0 access-list vpnclient extended permit ip 10.xxx.xxx.0 255.255.255.0
172.31.254.0 255.255.255.0 access-list outside_1_cryptomap extended permit ip 10.xxx.xxx.0
255.255.255.0 10.xxx.0.0 255.255.255.0 pager lines 24 logging enable logging asdm informational mtu inside 1500 mtu outside 1500 mtu dmz 1500 ip local pool bemcopool 172.31.254.1-172.31.254.100 icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-524.bin no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0.0.0.0 0.0.0.0 route outside 0.0.0.0 0.0.0.0 83.xxx.xxxx.141 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00 timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute http server enable http 10.xxx.xxx.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto map outside_map 1 match address outside_1_cryptomap crypto map outside_map 1 set pfs group1 crypto map outside_map 1 set peer xxx.xxx.xxx.129 crypto map outside_map 1 set transform-set ESP-3DES-MD5 crypto map outside_map interface outside crypto isakmp identity address crypto isakmp enable outside crypto isakmp policy 10 =A0authentication pre-share =A0encryption 3des =A0hash md5 =A0group 2 =A0lifetime 86400 telnet 87.xxx.xxx.131 255.255.255.255 outside telnet timeout 5 ssh 0.0.0.0 0.0.0.0 outside ssh timeout 5 console timeout 0 !
tunnel-group DefaultRAGroup general-attributes =A0address-pool (outside) bemcopool tunnel-group xx.xx.xx.129 type ipsec-l2l tunnel-group xx.xx.xx.129 ipsec-attributes =A0pre-shared-key * ! class-map inspection_default =A0match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map =A0parameters =A0 message-length maximum 512 policy-map global_policy =A0class inspection_default =A0 inspect dns preset_dns_map =A0 inspect ftp =A0 inspect h323 h225 =A0 inspect h323 ras =A0 inspect rsh =A0 inspect rtsp =A0 inspect esmtp =A0 inspect sqlnet =A0 inspect skinny =A0 inspect sunrpc =A0 inspect xdmcp =A0 inspect sip =A0 inspect netbios =A0 inspect tftp ! service-policy global_policy global prompt hostname context
I have these settings:
ssh x.x.x.x x.x.x.x outside (ip mask, interface f.eks if your ip adress is
10.0.0.2 and behinde interface inside, it would be ssh 10.0.0.2 255.255.255.255 inside)
I also have:
aaa authentication ssh console LOCAL username myname password yourpassword
skrev i melding news: snipped-for-privacy@c36g2000yqn.googlegroups.com... I'm trying to get SSH to work on the ASA from a remote location, i've creayed the SSH key etc... but still no joy, can anyone point me in the right direction?
: Saved : Written by enable_15 at 06:06:56.398 UTC Thu Mar 19 2009 ! ASA Version 7.2(4) ! hostname xxxx domain-name default.domain.invalid enable password E4uBcGsdaUuWMrXz encrypted passwd 2KFQnbNIdI.2KYOU encrypted names ! interface Vlan1 nameif inside security-level 100 ip address 10.xx.xx.xx 255.255.255.0 ! interface Vlan2 nameif outside security-level 0 ip address 83.xxx.xxx.142 255.255.255.252 ! interface Vlan3 shutdown no forward interface Vlan1 nameif dmz security-level 50 ip address 192.168.64.10 255.255.255.0 ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 ! interface Ethernet0/2 ! interface Ethernet0/3 ! interface Ethernet0/4 ! interface Ethernet0/5 ! interface Ethernet0/6 ! interface Ethernet0/7 switchport access vlan 3 ! ftp mode passive dns server-group DefaultDNS domain-name default.domain.invalid access-list nonat extended permit ip 10.xxx.xxx.0 255.255.255.0
10.xxx.xxx.0 255.255.255.0 access-list nonat extended permit ip 10.xxxx.xxx.0 255.255.255.0 172.31.254.0 255.255.255.0 access-list vpnclient extended permit ip 10.xxx.xxx.0 255.255.255.0 172.31.254.0 255.255.255.0 access-list outside_1_cryptomap extended permit ip 10.xxx.xxx.0 255.255.255.0 10.xxx.0.0 255.255.255.0 pager lines 24 logging enable logging asdm informational mtu inside 1500 mtu outside 1500 mtu dmz 1500 ip local pool bemcopool 172.31.254.1-172.31.254.100 icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-524.bin no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0.0.0.0 0.0.0.0 route outside 0.0.0.0 0.0.0.0 83.xxx.xxxx.141 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00 timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute http server enable http 10.xxx.xxx.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto map outside_map 1 match address outside_1_cryptomap crypto map outside_map 1 set pfs group1 crypto map outside_map 1 set peer xxx.xxx.xxx.129 crypto map outside_map 1 set transform-set ESP-3DES-MD5 crypto map outside_map interface outside crypto isakmp identity address crypto isakmp enable outside crypto isakmp policy 10 authentication pre-share encryption 3des hash md5 group 2 lifetime 86400 telnet 87.xxx.xxx.131 255.255.255.255 outside telnet timeout 5 ssh 0.0.0.0 0.0.0.0 outside ssh timeout 5 console timeout 0 !
tunnel-group DefaultRAGroup general-attributes address-pool (outside) bemcopool tunnel-group xx.xx.xx.129 type ipsec-l2l tunnel-group xx.xx.xx.129 ipsec-attributes pre-shared-key * ! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp ! service-policy global_policy global prompt hostname context
