ASA 5505 and PPPoE PPP link down:LCP down / Peer Terminated
Feb 27, 2009 1 Replies
hi NG,
i'm running a ASA 5505 and loosing the connection every so often. The DSL Signal is not an issue, since my Zywall2 works properly in combination to my DSL-Bridged-Mode Router. The Bridged Mode Router is a: Zyxel p623me-t1, where by the ATM loopback test is OK, noise margins up/down seem ok as well.
While running the ASA after around 25-40 Minutes i get following messages:
%ASA-3-403503:PPPoE:PPP link down: %ASA-3-403503:PPPoE:PPP link down:Peer Terminated %ASA-3-403503:PPPoE:PPP link down: %ASA-3-403503:PPPoE:PPP link down:LCP down %ASA-3-403503:PPPoE:PPP link down: %ASA-3-403503:PPPoE:PPP link down:LCP down %ASA-3-403503:PPPoE:PPP link down: %ASA-3-403503:PPPoE:PPP link down:Peer Terminated %ASA-3-403503:PPPoE:PPP link down: %ASA-3-403503:PPPoE:PPP link down:LCP down
My ASA now will hardly ever reconnect again, without me rebooting the Bridged-Mode-Router. Following shows a sample of a debugged connection etablishing and connection failing I asume not the link is the issue, i could be something about diffrent PPP(oE) timing... any suggestions are welcome.
thank you
======================================================================================================== Connection was last, now starting debugging: ========================================================================================================
ciscoasa# debug pppoe error 1 ciscoasa# debug pppoe event ciscoasa# debug pppoe packet
ciscoasa# PPPoE: send_padi:(Snd) Dest:ffff.ffff.ffff Src:0021.a0a8.ec70 Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:09=PADI Sess:0 Len:12 PPPoE: Type:0101:SVCNAME-Service Name Len:0 PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: padi timer expired
Feb 26 2009 21:15:37: %ASA-4-411002: Line protocol on Interface Ethernet0/0, changed state to down Feb 26 2009 21:15:41: %ASA-4-411001: Line protocol on Interface Ethernet0/0, changed state to up PPPoE: send_padi:(Snd) Dest:ffff.ffff.ffff Src:0021.a0a8.ec70 Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:09=PADI Sess:0 Len:12 PPPoE: Type:0101:SVCNAME-Service Name Len:0 PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: padi timer expired
======================================================================================================== Until now no connection!! Rebooting the Bridged-Mode-Router ========================================================================================================
Feb 26 2009 21:18:45: %ASA-4-411002: Line protocol on Interface Ethernet0/0, changed state to down Feb 26 2009 21:18:49: %ASA-4-411001: Line protocol on Interface Ethernet0/0, changed state to up
======================================================================================================== Around 20 minutes later... ========================================================================================================
PPPoE: PPPoE:(Rcv) Dest:0021.a0a8.ec70 Src:0090.1a41.45bc Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:07=PADO Sess:0 Len:54 PPPoE: Type:0102:ACNAME-AC Name Len:18 PPPoE: ipc-bsg620-r-br-02
PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: Type:0101:SVCNAME-Service Name Len:0 PPPoE: Type:0104:ACCOOKIE-AC Cookie Len:16 PPPoE: 7CFDEDAD PPPoE: C411B3E3 PPPoE: B651C71F PPPoE: DFCC3DEA PPPoE:
PPPoE: PADO
PPPoE: send_padr:(Snd) Dest:0090.1a41.45bc Src:0021.a0a8.ec70 Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:19=PADR Sess:0 Len:54 PPPoE: Type:0102:ACNAME-AC Name Len:18 PPPoE: ipc-bsg620-r-br-02
PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: Type:0101:SVCNAME-Service Name Len:0 FePbP P2o6E 200:9 2T1y:p36e:11::0 1%0AS4A-:3A-40C3C5O03O:PKPIPEo-E:PAPCP Cloionkk ideow nL:e
0neb 2:61 62 0
03:P21P:3P6o:11E:: %7ACSFAD-3E-D4A0D3 5 n PPPPoEP:oPEPP: l inCk 4do1w1n:LBC3PE d3o w
PPPoE: PPPoE:(Rcv) Dest:0021.a0a8.ec70 Src:0090.1a41.45bc Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:65=PADS Sess:7292 Len:54 PPPoE: Type:0101:SVCNAME-Service Name Len:0 PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: Type:0102:ACNAME-AC Name Len:18 PPPoE: ipc-bsg620-r-br-02
PPPoE: PADS
PPPoE: IN PADS from PPPoE tunnel
PPPoE: Opening PPP link and starting negotiations.
======================================================================================================== Connected!! now following samples of ACLs.. from inbound traffic being denied, profing it working.. ========================================================================================================
Feb 26 2009 21:36:45: %ASA-4-106100: access-list outside_access_in denied icmp outside/85.1.147.53(3) -> inside/IP_ADDRESSS_OF_ASA(3) hit-cnt 1 first hit [0x2c1c6a65, 0x0] Feb 26 2009 21:36:45: %ASA-4-106100: access-list outside_access_in denied icmp outside/84.73.210.252(3) -> inside/IP_ADDRESSS_OF_ASA(3) hit-cnt 1 first hit [0x2c1c6a65, 0x0]
3|Feb 26 2009 21:56:40|403503:PPPoE:PPP link down:
3|Feb 26 2009 21:56:40|403503:PPPoE:PPP link down:Peer Terminated
3|Feb 26 2009 21:56:40|403503:PPPoE:PPP link down:LCP down
======================================================================================================== a few minutes later, disconecting again... ========================================================================================================
Hi NG,
snip of debug, while failing, loosing the connection:
====loosing connection debug begin=========
ciscoasa# PPP va close, device = 1 PPPoE: PPPoE:(Rcv) Dest:0021.a0a8.ec70 Src:0090.1a41.45bc
Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:A7=PADT Sess:4178 Len:0 PPPoE: PADT
PPPoE: Shutting down client session
Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:09=PADI Sess:0 Len:12 PPPoE: Type:0101:SVCNAME-Service Name Len:0 PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: send_padi:(Snd) Dest:ffff.ffff.ffff Src:0021.a0a8.ec70
====loosing connection debug end=========
====successful connect debug begin=========
Debug of an successful connection:
ciscoasa# ciscoasa# PPPoE: send_padi:(Snd) Dest:ffff.ffff.ffff Src:0021.a0a8.ec70
PPP virtual access open, ifc = 2 LCP Option: MAGIC_NUMBER, len: 6, data: 5ab212fb PPPoE: Type:0101:SVCNAME-Service Name Len:0 LCP Option: Max_Rcv_Units, len: 4, data: 05d4 LCP Option: AUTHENTICATION_TYPES, len: 5, data: c22305 LCP Option: MAGIC_NUMBER, len: 6, data: 59290a99
PPP lcp reqci: returning CONFACK.LCP Option: Max_Rcv_Units, len: 4,
data: 05d4 LCP Option: AUTHENTICATION_TYPES, len: 5, data: c22305 LCP Option: MAGIC_NUMBER, len: 6, data: 59290a99 LCP Option: MAGIC_NUMBER, len: 6, data: 5ab212fb PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: padi timer expired
LCP Option: AUTHENTICATION_TYPES, len: 5, data: c22305 LCP Option: MAGIC_NUMBER, len: 6, data: a7b14edc LCP Option: MAGIC_NUMBER, len: 6, data: 48bcbf18
PPP lcp reqci: returning CONFACK.LCP Option: AUTHENTICATION_TYPES, len:
5, data: c22305 LCP Option: MAGIC_NUMBER, len: 6, data: a7b14edc LCP Option: MAGIC_NUMBER, len: 6, data: 48bcbf18 PPPoE: PPPoE:(Rcv) Dest:0021.a0a8.ec70 Src:0090.1a41.45bc
PPPoE: PADO
Type:0x8863=PPPoE-Discovery PPPoE: Ver:1 Type:1 Code:65=PADS Sess:4178 Len:54 PPPoE: Type:0101:SVCNAME-Service Name Len:0 PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4 PPPoE: 00000001 PPPoE: Type:0102:ACNAME-AC Name Len:18 PPPoE: ipc-bsg620-r-br-02
PPPoE: PADS
====successful connect debug end=========
"colin" schrieb im Newsbeitrag news:49a7d9a5$0$146$ snipped-for-privacy@newsspool.solnet.ch...
