Aironet 1200 firmware update problem
Jun 03, 2005 2 Replies
Aironet 1200 firmware update problem open original image
after a failed firmware update my Aironet 1200 Access Point comes up "empty" - with the minimal boot load that is.
I can connect to it through the console, so I guess the machine is recoverable but how do I get it to properly load my firmware and config?
Anyone there who can give me a hint?
Thanks,
Assuming that you're getting an "ap:" prompt when you connect via the console port, then here's the drill:
Aaron
Thanks, Aaron!
That was exactly what I was looking for...
