Aironet 1100 OpenVPN and WPA2 authentication
Apr 03, 2006 2 Replies
Hi, I have this little problem, I would like to configure this scenario
WPA2 ------>Network WEP128--->Access List 101--->IP: aaa.bbb.ccc.ddd ---> OpenVPN --->
Network
Problem is that I found solution only using VLANs, but I do not want to reconfigure switches. Do somebody have idea how to done it without configuing VLANs on switches?
My first idea come to configure AP to use VLAN and if switch is not configure VLAN, it will ignore APs tags, but actually it not work as I expected.
Is the AP Trunk with the switch ?
no, but I solved problem in other way, I found new drivers which support WPA...
