Hello I have a remote router that will change its ip in a couple of weeks, I would like to ad a second ip for this change. Can this be done? thanks.
adding a second ip to a cisco 1700 interface
Aug 12, 2005
int x
ip address x.y.z.w 255.255.255.0 secondary
Note: The mask is just an example.
thanks I will try that
Do i have to add a second default gateway too? do i just repeat this line with the new gateway ip route 0.0.0.0 0.0.0.0 Mygatewayhere
what about the after the change can i just delete the primary ip?
thanks
