Active FTP on PIX not functioning
Apr 08, 2005 1 Replies
I have a PIX with fixup protocol ftp 21 enabled. I use a few scripts that will ftp to certain sites and they use the Windows ftp client, which only supports active mode. For some reason, I can connect to the ftp server and login, but when I try to do a directory listing, it just hangs. Anyone know how I can fix this issue?
Ftp to some other ftp servers that you know works without going thru the Pix. And then, you may want to up the logging level on the pix, and check the log on why.
