AAA Best Pratices?
Feb 02, 2006 8 Replies
Most relevant reply
Andrey Tarasov
Hello, Matt! You wrote on Fri, 03 Feb 2006 14:23:43 -0500: ??>> Also tacacs accounting is very helpful to find out who did what ??>> when. MW> I'll have to look up how to do that. This TACACS accounting MW> better than having the device log back to a remote syslog? It's…
AAA Best Pratices? open original image
Newsgroup -
We are in the planning stages of implementing AAA on all our of Cisco devices.
Does Cisco have a "best practices" document out there someplace that describes a robust way to do this? (We have two RADIUS servers in geographically diverse locations.)
Thanks!
- Matt
This doesn't actually answer your question but can help ...
BernieM
Thanks, I'll look at that!
Maybe we can just start a discussion here instead... since I've very new to AAA, here's the setup I had in mind -
1.) Disable authentication on the console port. 2.) Create one local user on each device in case the RADIUS services go down. 3.) Enable SSH on as many devices as possible.
Does this seem like a reasonable configuration?
- Matt
Hello, Matt! You wrote on Fri, 03 Feb 2006 11:00:09 -0500:
MW> Maybe we can just start a discussion here instead... since I've MW> very new to AAA, here's the setup I had in mind -
MW> 1.) Disable authentication on the console port.
Don't disable. Use local account.
MW> 2.) Create one local user on each device in case the RADIUS MW> services go down.
Yep. It's also useful for #1 above. Use secret command so password couldn't be easily decoded.
MW> 3.) Enable SSH on as many devices as possible.
Yep. And disable normal telnet access.
MW> Does this seem like a reasonable configuration?
Also tacacs accounting is very helpful to find out who did what when.
With best regards, Andrey.
Fair enough.
Good, that's what I was planning on doing.
I'll have to look up how to do that. This TACACS accounting better than having the device log back to a remote syslog?
- Matt
It's different :-) TACACS accounting will give you exact information what commands was entered on the device, when, under which account and what IP address connection was established from. Only thing you will get in syslog from Cisco routers and IOS switches is that "configured from ... by ...". Unless there is some new functionality I'm not aware of.
Ohh, neat. :)
I'll dig into that. Thanks for the heads-up!
- Matt
AAA or ACS ? i am actually in ACS team in Cisco TAC..What exactly is your question?
I'm looking for a good example to follow for setting up our Cisco devices to use a RADIUS server for secure access. (Mostly 2620 routers,
2950 switches and 1200 access points.)
I can come up with something that "works", but having a mature example to follow is often very helpful as it'll cover situations that I might not have thought of! :)
- Matt
