877 VPN problem to 837
Oct 02, 2006 5 Replies
Jump to replies (5)
877 VPN problem to 837 open original image
Hi
I am pulling my hair out here :)
Have two Cisco small office ADSL routers, 837 and 877 Cisco 837 router has been tested and works well with site to site ipsec VPN to other routers. But not the new 877 router i got.
Problem: Cisco 877 is also able to establish ike negotiation and successfully initate ipsec, however there is no data going through it. it seems like some problm with ACL and i desperately need help. Config for both routers is below. It definitely works for 827 and 837 routers, but i think i think i may be missing something because IOS in 877 router is new.
837 configuration ---------------------------------------- version: 12.3(2)XC2
crypto isakmp policy 140
hash md5
authentication pre-share
lifetime 3600
crypto isakmp key 0 mysecretkey address 165.228.212.18
crypto ipsec transform-set allsites esp-des esp-md5-hmac
crypto map vpnmap 140 ipsec-isakmp
set peer 165.228.212.18
set security-association lifetime seconds 28800
set transform-set allsites
set pfs group1
match address 140
interface Ethernet0
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface Dialer1
ip address 203.142.244.16 255.255.255.0
crypto map vpnmap
ip nat inside source list 102 interface Dialer1 overload access-list 102 deny ip 192.168.3.0 0.0.0.255 192.168.190.0 0.0.0.255 log
access-list 102 permit ip 192.168.3.0 0.0.0.255 any
access-list 140 permit ip 192.168.3.0 0.0.0.255 192.168.190.0 0.0.0.255
dialer-list 1 protocol ip permit
877 configuration ----------------------------------------
version: 12.3(8r)YI2
hash md5
lifetime 3600
crypto isakmp key 0 mysecretkey address 203.142.244.16
set peer 203.142.244.16
set pfs group1
match address 140
interface Vlan1
ip address 192.168.190.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface Dialer1
ip address 165.228.212.18 255.255.255.0
crypto map vpnmap
ip nat inside source list 102 interface Dialer1 overload access-list 102 deny ip 192.168.190.0 0.0.0.255 192.168.3.0 0.0.0.255 log
access-list 102 permit ip 192.168.190.0 0.0.0.255 any
access-list 140 permit ip 192.168.190.0 0.0.0.255 192.168.3.0 0.0.0.255
Hi Igor,
You may wish to investigate Cisco 800 Router Documentation:
as well as the Cisco 877 Config Wizard:
Hope this helps.
On both routers use:
debug crypto isakmp debug crypto ipsec
then
clear crypto sa
to make sure all VPN stuff is cleared and do a ping or whatever is appropriate to bring up the VPN. The routers will spit out several thousand lines of debug to the console and a close inspection of this should show where the problem lies.
JR
I agree.
As a confidence booster, I use 837 and 877 and have no issue with crypto.
The config that you have posted looks OK. I use different parameters,
crypto isakmp policy 1 encr 3des hash md5 authentication pre-share group 2
crypto isakmp key xxx address 8..... crypto isakmp key xxx address 8..... ! ! crypto ipsec transform-set Home esp-3des esp-md5-hmac
! crypto map Home 2 ipsec-isakmp set peer 8....... set transform-set Home match address 110
This works.
I do notice that you have pretty old 877 software. Much as I hate the idea of "blind" upgrades I do get the idea there there have been some issues with
870 software. So, why not try a re-grade.
12.4(9)T1 is the latest.
You might add to the debugs debug crypto isakmp error debug crypto ipsec error
If you can possibly compare a working crypto set with a broken one then yuo might get an idea of what is wrong.
sh cry ip sa
WHAT YOU ARE ENCRYPTING local ident (addr/mask/prot/port): (8...9/255.255.255.255/47/0) remote ident (addr/mask/prot/port): (8...4/255.255.255.255/47/0)
When the tunnel is UP you get something like this FOR EACH DIRECTION inbound esp sas: spi: 0x9163F57(152452951) transform: esp-3des esp-md5-hmac , in use settings ={Tunnel, } conn id: 2006, flow_id: C83X_MBRD:6, crypto map: Home sa timing: remaining key lifetime (k/sec): (4424389/509) IV size: 8 bytes replay detection support: Y Status: ACTIVE
Also chek that you NAT is OK (your config looks OK) sh ip nat tr
I enabled debug
But strange thing is on either routers it does not show any debugging for IPSEC
You do need to know how to drive debug, it is not entirely obvious, until you know:-)
Debug output goes to the logging "system" lets call it.
The logging system then sends it to whatever places are configured and you then can view it there.
To see logging on a telnet session (strictly, any vty session) you have to have:-
conf t logg monitor debug ! this is the ("not configured" default) end
Then you need to enter the
terminal monitor
command on the sesion that you want to have the logging output sent to.
Alternatively:
conf t logg buffered 60000 debug end
and then sh log
Or both.
Read the cisco debugging advice regarding CPU. It is possible to stop a router from functioning such that it requires a power cycle if you turn on debugging.
I know 'cos I have done it.
BTW term no mon turns it off and not as might be expected no term mon
