2600XM startup loop
Aug 11, 2005 1 Replies
On a Cisco 2611XM IOS IP Plus IPSec 3DES v12.28 I was getting "Low Memory - try again later" console messages. The router would hang and after a reload would work for an hour or two and hang again. I changed the IOS back to IP Plus v12.19 which I knew worked previously. However, now when the system boots I get -
Unexpected exception to CPUvector 1100, PC = 0
-Traceback= 0 803EF60C 803EF068 803EF444 803F061C
I cannot break into these messages to get to RMMON. I swapped out the memory but still get the same message. I'm stuck - any help appreciated... Ned
better open a tac case to decode this traceback
