1720 and 3xeth
May 02, 2005 1 Replies
Hello again! Maybe I will try to define the problem in other way. How can I force router to choose route based on the info what interface the packet came from? There should be done even more. The packet going through int. eth0 must be submited to NAT, and returning packet also go through eth0. Simultaneously, the same operation must be done on eth1, which is also connected to WAN.
Adam
you want to use PBR, policy based routing. I don't knwo exactly what you are doing but a route-map with "match interface" will probably achieve what you want.
