10/100 FE WIC for 1721?
Mar 05, 2008 3 Replies
Doug McIntyre
Yes, but thats a switch on a card, with only one L3 interface back. And it should be at 10Mbps back to the router. No, it comes back as Ethernet from what I remember. Also, the 1721 maxes out around 4-5Mbps from what I remember.
Is the only 10/100 WIC for the 1700 Series the 4Port Switch?
I have A 16Meg Download internet connection and wanted to use my 1721. It has a WIC-1ENET which is only 10base
The 4Port Switch is also a FE Interface Correct?
thanks
A 1721 only rated at 6Mbps of throughput.
4-5Meg on the WIC Slots?
Double Dog Dang.
So I guess I need to Go with the PIX then...
