time and questions in final3?
May 08, 2005 1 Replies
Aubrey Adams
The time depends upon the policy of your academy - your instructor can set it from 1 hour to 3 hours in duration. You should have been given this assessment information at the start of the semester. The current English form for this exam has 50 questions - a mix of Mutliple…
Do any know how much time is for semester 3 final? Some says 1:15, others 1:30. How many questions is there?
The current English form for this exam has 50 questions - a mix of Mutliple Choice Single Answer and Multiple Choice Mutliple Answer items.
The majority of questions are scenario type - graphics of topologies with descriptions requiring you select the command/s; which will be difficult regardless of the time limit if you haven't done the labs and/or skills based assessment first - although there are a couple of semester 1 level gimme questions about switches, routers, collision and broadcast domains, etc.
Get 80% - 90% for this exam and you do know something about routing and switching.
Good luck!
Aubrey
