Help with cisco 828 config
Mar 02, 2006 2 Replies
Our company has two locations...the main location with all the servers (2) and a small administration location. On each location we have a cisco 828 with a sdsl line (256/256) between the locations.
How do i have to configure the cisco's so it's look like there are all in main location. Example: when i plug a computer in the small location, i want that it get dhcp from a server in the main location.
Main Location Other location
lan 100mb dsl 256/256 lan100mb
----------Cisco 828-------------------Cisco 828---------- 10.22.0.31 10.22.0.32
I have had two scripts from my phone company, however they are configured where the small location is another subnet.
How do I have to change the scripts.
Many thanks,
Rien.
================================================== Current Main Location Script...... ================================================== ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname 1046323 ! no logging buffered enable secret 5 xxxxx ! ip subnet-zero ! ip cef ! ! ! interface Ethernet0 ip address 10.22.0.201 255.255.255.0 no cdp enable hold-queue 32 in hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive pvc 2/32 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl equipment-type CPE dsl operating-mode GSHDSL symmetric annex B dsl linerate AUTO ! interface Dialer0 ip unnumbered Ethernet0 no ip proxy-arp encapsulation ppp dialer pool 1 dialer-group 1 no cdp enable ppp chap hostname xxxxx ppp chap password 0 xxxxx ppp pap refuse ppp ipcp address accept ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 no ip http server ! ! dialer-list 1 protocol ip permit no cdp run ! line con 0 exec-timeout 0 0 password xxxxx login stopbits 1 line vty 0 4 exec-timeout 30 0 password xxxxx login length 0 ! scheduler max-task-time 5000 end
================================================== Current Small Location Script ================================================== ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname 6661ev ! no logging buffered enable secret 5 xxxxx ! ip subnet-zero no ip source-route ! ip cef ! ! ! interface Ethernet0 ip address 10.22.1.201 255.255.255.0 no cdp enable hold-queue 500 in hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive pvc 2/32 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl equipment-type CPE dsl operating-mode GSHDSL symmetric annex B dsl linerate AUTO ! interface Dialer0 ip unnumbered Ethernet0 no ip proxy-arp encapsulation ppp dialer pool 1 dialer-group 1 no cdp enable ppp chap hostname xxxxx ppp chap password 0 xxxxx ppp pap refuse ppp ipcp address accept ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 no ip http server ! ! dialer-list 1 protocol ip permit no cdp run ! line con 0 exec-timeout 0 0 password xxxxx login stopbits 1 line vty 0 4 exec-timeout 30 0 password xxxxx login length 0 ! scheduler max-task-time 5000 end
As far as I can remember you need to allow dhcp relay from your small location, I think the command is somethine like ip dhcp relay or something similar. Hope this helps.
Cheers
CK
