multimode fiber + GBIC
Jan 15, 2005 3 Replies
Jump to replies (3)
multimode fiber + GBIC open original image
How to plug multimode fiber to Cisco WS-C2950SX on the one side and Catalyst
3550 12G on the other? What connectors do I need?
Thanks Lucas
Hi Lucasz,
I don't want to diminish the huge pool of expertise that you are tapping into when asking for advise on the Usenet, but if I were you, I would not base my purchasing decision on the answers you can receive here. You are talking about parts that affect operation of multi-thousand dollar equipment. There is always a possibility that some important info is missing. Besides, in your case both boxes are by the same manufacturer, so why don't you just give them a call?
The datasheets for the devices do have this information in them. (ie.
I'm assuming
Since you only specify the 3550-12G which really has no connectors on it without adding on things, I'm guessing what you're actually going to be using.
But if this is more than just a single quick connection, you'll probably want to pull fiber to patch panels, and then if things change you can just change out your patch cord rather than redo the fiber terminations.
I forgot to mention that my question is just theoretical. I am not going to implement this network in the near future. I need to know how to physically join multimode fiber with above devices and what kind of connectors to use.
Thanks, Lucas
