best size
May 09, 2006 1 Replies
Hi
I've been browsing panduit's website to look for their cable labeling solutions. I thought that I will see a couple of label formats and choosing one would be easy. I was shocked (and got totally confused) to find that there are dozen of different sizes that I simply don't know which one to choose.
From experience: What is the best size for CAT5e/CAT6 cable labels?
TIA Paolo
Typically 1" wide with a .75 - 1" hight of write-on height and 1.5 -
1.75 overall height
The actual product will also depend if you intend to hand write or print in a thermal transfer or laser printer.
Joe Golan, RCDD
