Rhino 3000
Jun 13, 2006 3 Replies
Jump to replies (3)
Just bought the Rhino 3000 label maker and I'm tickled pink. Really a well-thought out, easy to use labeller with lots and lots of extra features like built-in serialization of labels, memory recall, built in symbols and common room names, a nice black rubber boot, a backlight LCD (very, very handy) and a keyboard layout similar enough to a PC keyboard to be very easy to figure out. I've applied labels lengthwise to RG6 and then fished it through some very narrow openings without scraping the labels off (I'm using their nylon stock).
All in all, a very neat tool. I highly recommend it for cable labeling as well as all sorts of other applications. Works great on my Hi-8 videotapes and lots of other places where I used to use Sharpies. I recently discovered, to my dismay, that for whatever reason, the silver Sharpies will actually rub off RG6 and I had to re-tone some cables to ID them again as a result. With the Rhino, all I do is type the one label and print as many copies as I need. Sure's a lot faster than trying to write carefully on a round wire with a fat-tip pen!
-- Bobby G.
The labels are pretty pricey - that's a serious downside . . . I knew I should have ordered more. Which type of labels do you use?
-- Bobby G.
I'm using the nylon also. The cheapest place i have found them is tiger direct.
