Upload speed problems with large files
Aug 22, 2005 7 Replies
Jump to replies (7)
Upload speed problems with large files open original image
I've been dealing with an upload speed problem that I think I've found where to look, but I don't know what to do about it!
When I upload large files (>2MB) to a FTP server, with each file the upload speed begins at 2Mbps (Verizon FIOS) and then slowly deteriorates to about 250Kbps and holding steady until that file completes and the next file begins at the full 2Mbps again. This happens no matter the FTP client I use and no matter the server I upload to. After changing from Comcast to Verizon, and changing routers from Linksys to Dlink, I've decided that the problem has to lie in the WinXP Pro networking setup. Here is where I am stuck - I've NO IDEA what to do about that, and I can't find any info on other people that have had this problem and solved it.
Can anyone point me in the right direction??? I need to know what aspects of my networking setup could be affecting this problem.
Thanks in advance for any input and advice you could give!!
  • Dan in Dallas :
Most likely your ISP caps your upstream speed.
You don't mention what kind of connection you have. Most broadband connections are 10 times as fast (or more) downstream versus upstream. The reason your uploads are slower is because you have a slower upstream connection, probably 256kbps, which would account for your speeds. The
2mbps initial speed is only reporting the speed at which you fill the associated buffers and caches.
Actually, I did mention that I'm on Verizon FIOS with a 2Mbps upload speed (5Mbps download, but that's not the issue). There is no cap - as I mentioned, the speed starts out at full-speed, then *decreases* over time on a per-file basis. Each new file starts out at full speed.
I am monitoring the transfer speeds live, so I know for sure what I'm getting.
Where are you uploading to? You're limited by the capabilities of the server being uploaded to. You're also limited by every link between you and the end point.
What you describe could be a buffer someplace filling up. There's no easy way to test where that might be, but if it's anywhere outside your Verizon FIOS MAN, your 2Mbps cap may be irrelevant.
Is this a wireless connection or wired?
Upload speed always is dependent on the recieve speed at the other end. If this is upload to your Verizon personal web/file space, Verizon might well be limiting upload simply to prevent its servers from being used for "illicit" purposes. FTP sites might also be limiting receipts to help with sharing resources. You might try
or
for upload speed tests on servers with more capability.
Q
Wired connection. Upload to non-Verizon site via FTP.
So it could be a "buffer filling up"? Could that be anywhere in the path between me and the destination? It does appear that some days, the problem exists, and some days it does not.
