Still can't access remote admin on D-Link DI-804
Jul 12, 2004 4 Replies
Jump to replies (4)
Still can't access remote admin on D-Link DI-804 open original image
This is supposed to be easy but I just can't get it to work!!!????
I changed the remote admin port to 8080, 2000, 20000, etc, but I still can't connect to the web interface from **outside** the LAN. The browser just returns with a "The page cannot be displayed etc.. etc.. Cannot find server or DNS Error" standard Internet Explorer error message. Within the LAN I can enter the admin tool without a problem on all configured ports. I don't know if it's relevant, but I have a DMZ zone set up that redirects to 192.168.0.100. I tried disabling the DMZ, but I still can't connect to the admin web interface.
I have the same exact internet gateway/router in another office, with the same exact problem. Can anyone tell me what's happening here????
By the way, DMZ points to a IIS Web Server (port 80) in the LAN, so my ISP is NOT blocking port 80.
Thanks for your help..
Have you tried asking the experts here:
Try telnetting to the web admin port, using "telnet IPADDRESS: 80" or whatever port http is running on. Run ethereal to see what is going on. J--
Safe Computing, Home wired and wireless networking tips. ....You spend your whole life figuring out what you should have done with it, let alone what it was all about. And then your children get to do it all over again..
Make sure that the Remote Management IP Address is set to "*" (asterisk, no quotes)
idc had written this in response to
: Hi, If your firmware is latest 1.51b16 the solution is to downgrade to D-Link_804HV_V1.50b08.BIN It's checked :)
