Hi, Anyone using one? Do you like it? Care to comment? TIA,
- posted
12 years ago
Zyxel dual band router NBG5715
Not me. I don't go for MIMO and speed. I want reliability and features.
Some reviews:
Page 2 has some nasty comments about the quality.
VPN only between routers and requiring static IP? Yech.
Hi, This router seems running OpenWrt which is interesting.
Well, they did give a bit of a clue with the naming - NBG...
Yep:
No source code in the "opensource" directory:
Looks like Zyxel has donated a unit for porting:
but the NBG5715 isn't on the OpenWRT supported devices list quite yet.
Hi, It has Luci and heavily patched OpenWrt for sure when f/w source list as well as memory dump suggests. Definitely this is a router with the case of WIP. I ordered one to play with it.
