Simultaneous Dual Band - practical uses in a 'G' & 'N' environment
Jan 22, 2010 5 Replies
Jump to replies (5)
Simultaneous Dual Band - practical uses in a 'G' & 'N' environment open original image
I'm trying to make an informed buying decision as we think about upgrading the current Home Network; right now there is a Linksys 'G' band router downstream from a DLS line . (2 are hardwire 10/100bT & two others via 80211g wireless with an additional single draftN unit in 'G' mode).
(Usually there are no more than three online at any given time.)
Right now I have the router locked to 'G'-only mode (no 'B' or mixed mode), and any adapters bought in the future will likely be some sort of draftN type, so what I'm wondering is:
- Are Simultaneous Dual Band routers able to avoid a bottleneck (if there is really one after all) when used with both N and G clients and hooked to a 1.5M DSL residential line? (Or, conversely, is it marketing hype and/or overkill?)
- Has practical experience shown one brand/model to shine over the others?
- Is there a great deal of performance plateaus between single radio, Dual Band, and Simultaneous Dual Band routers?
berk
Even with 'G'-based systems, with respect to using the internet connection,
*typically* the bottleneck is the internet connection, and not the wireless speeds.
The wireless become the bottleneck when transferring data over the LAN, between PCs.
as others will probably mention - if the main or only traffic is to the DSL line and the Internet.... vs any in-house data/streaming transfers -
Then a 1.5mbit DSL vs a 54mbit WiFi (G) is hardly an issue :) Heck - even a (B) at 11mbits is not an issue with a 1.5 DSL line
In fact - you might perform a speed test and see your actual download speeds...
It might seem stupid and obvious but actually having it spelled out like that does help.
I took a chance and ran it by the NG, Thx.
berk
Meanwhile, at the alt.internet.wireless Job Justification Hearings, TBerk chose the tried and tested strategy of:
Something else that isn't obvious to most people is that Wifi speeds don't represent an attainable throughput - IME being connected at 54Mbps equals a throughput of about 22Mbps for example, with similar percentages at other speeds. I haven't used N, but I've no reason to believe it'll be substantially different.
It's a similar story with DSL too, with various overheads meaning that IP throughput will be about 87% of your sync speed.
Yes, it's just the PHY rate. The TCP throughput rate will be some fraction of the actual connected rate, which is some fraction (usually) of the listed or rated PHY rate.
Steve
