wireless security question
Threaded View
i have a laptop and a wireless router
how do i secure it so just that lap can connect to it
--------  Binary Usenet downloading made easy =---------
-=  Get GrabIt for free from http://www.shemes.com/ =-
Re: wireless security question
filter the mac address...so that your laptop, and only your laptop, can
connect.  should be in the router settings
Turn on encryption.  If you can, use WPA; if you cannot, use WEP.  Only
restricting access to certain MAC addresses is problematic because it is
possible for someone to determine some of those MAC addresses and to then
pretend to be one of those MAC addresses.
-Yves
Taking a moment's reflection, ss mused:
    As Yves stated, enable encryption.  That's the only way to be sure.  Use
WPA if you have it.  If not, use WEP, but change your passphrase
periodically.
Site Timeline
