Wireless Security
Nov 25, 2005 7 Replies
Jump to replies (7)
Options:-
  1. Turn it off again
  1. Tell us what hardware you've got and we might be able to tell you what your options are.
Aim for WPA if everything you have supports it.
David.
"Anthony Farmer" wrote in news:4386a892$0$28309$ snipped-for-privacy@news.optusnet.com.au:
Duane :)
Activate WPA with a secure passphrase (20-63 randomly generated characters) for WPA-PSK or activate WPA2 (it's better but not every AP or wireless card has it).
Hello all I am a newbie to wireless and was wondering about security I am in a block of units and as far as I know I am the only one within Cooee using wireless is there a way to beef up my security
any replies grateful
cheers
Tony
Can't remember whether WPA is an option on that one, if it is go for that if not, you're pretty much stuck with a WEP key. Just remember to change it every 10 minutes if you're paranoid.
Don't bother trying to hide the SSID broadcasts or set MAC filters, they're redundant in the context of security.
David.
So Sorry David I have a dlink di-524 router and a adaptor card dlink dwl-g510
also a dlink moderm dsl-302g
cheers
Tony
With random characters, 16 is sufficient, and even 12 is probably enough. The advice for more than 20 characters applies to word-based passphrases.
many thankx Dave I will try WPA if I can get into it ..lol.. Tony
