I think of the subject listings in a usenet group to be like headlines on a newspaper story. They are meant to grab the attention of someone scanning the listings. Newspaper headlines are often written by someone other than the author of the story. The story stands on its own. Jeff seems to go the other way, reading every article and seeing none of the subjects, unless I misunderstood him.
Nah, thanks. I continue to use a text newsreader for a text usenet. It works fine except for posts where the subject line is too long, and contradicts the information in the body of the posting.
Why would you ignore the sentence in your first post that certainly seems to contradict the subject line. You don't seem to quote that one in your continuing posts.
Your posting was not an example of succinct clarity.
I gave it only a cursory glance, thinking that 3 blocks in any direction probably wasn't going to work, so I didn't reply initially.
I didn't and wouldn't care if you were poaching a free connection, using a paid connection, or using your own connection in either direction. The radio distance and some of the challenges are the same.
Who's generalizing? I've made no comments about your political persuasions or honesty. Why would you question my logical thinking abilities? I suggest that you need to reexamine your stance, given that it is not a popular opinion. Right is right. Wrong is wrong, and there's plenty of space in between.
The comments from you about groups, cliques and allies almost had me laughing out loud. I I only see a couple of posters that I recognize, but I have had arguments with Jeff of style over substance. I don't like his style sometimes, but the substance, buried in the chaff, is correct. Mark McIntyre is familiar as someone that I do disagree with technically, but that's okay.
I see that someone made a beneficial technical comment, about putting a repeater midway in the link. I've seen that in long distance links, where there is some impediment in the way.
That's the answer that probably would have been third if you had accepted a criticism of you initial post without snapping at everyone who suggested an editorial change... save the one guy with the comment impugning your honesty and parentage. I would just ignore him.
