Here's one possibly for Jeff L as a follow up to my earlier Buffalo adaptor thread (the header of which I would insert here except that when I do it comes out as minute times new roman for some stupid reason!).
It turns out that the unpowered sitecom pocket hub I had been trying to use, does in fact have a socket for an external power supply, which I had not noticed and was not referred to in the user guide. (It turns out there is one FAQ on the sitecom site, and it is about which supply to use, and it would appear that my one from the old D-link router will do - once it has the right plug...)
Now, I have a number of power supply 'wall warts' from succesive cell phones, routers etc. and would like to use one of these rather than just buy yet another one.
Curiously, when I check the voltages of some of these devices it seems to be wildly at variance with what I understsand of what appears on the labels.
For example, I have a FRIWO FW 4199, which is supposedly 5V (equals sign with the bottom line as three dashes - what does this mean exactly: have been unable to look it up!) 410mA 2.05VA which both my old avo meters tell me is 9V not 5.
I also have a Sony AC-MZR37 which says 4.5V (same symbol) 500mA, which my meters tell me is turning out 7.5 V.
Another Nokia phone charger we have emits a high pitched whine...
Other 'warts' that I have do measure as what they are supposed to be, so what is going on? Are these devices just very unreliable or very difficult to measure, and what does this mean for the devices they are meant to power?
I was quite surprised to have to come back here with this question, but none of the manufacturer's sites I tried even seemed to have anywhere to look this sort of thing up, and I did not have a way of searching for the symbol with the broken equals sign. I probably ought to know what it means but it is a long time since I read any of this basic stuff and now I don't know where to!
Cheers,
S
