Power Supplies, Saving Money, and switching vs. Linear?
Mar 15, 2006 0 Replies
My electronics/wiring closet is costing $56/month to run. Ouch. Too much! So one-by-one I am changing things to be more power-conscious.
Starting with a big linear 12V power supply. Altronics 12V, 4A type linear power supply with battery backup: standard for alarms (a few years back). I currently draw about 500 ma continuously, (Not sure what my peaks are, but bells and sirens are powered separately.
This draws around 1.1 A on the AC line, so 132 Watts continuously. Big transformer, always warm. Seems wasteful.
IF I SWITCH TO A NEWER, SWITCHING POWER SUPPLY, say the Elk P412 (or any other you recommend) WOULD I DRAW MEASURABLY LESS AC CURRENT?
I am powering various motion detectors, InfraRed repeaters (Niles), a small, 7 Watt audio amplifier and a few other devices. Would the 100 MV ripple on the Elk power supply bring any problematic noise along with it?
Thanks for your suggestions
-Andrew
