I just finished testing a link between two buildings located about
1/3 of a mile apart using a pair these beasties. First, I'd like to thank Jeff Liebermann for the wonderful information and advice to a wireless novice about equipment selection and other requirements.The Tranzeos were *dead* easy to set up. Although the documentation was a bit on the sparse (to put it kindly) side, the web-based interface on the units was quite intuitive. Setting a few security parameters, changing the network setup, and a few other minor tweaks was all that was required. I then plugged them into one of my office networks across a hall from each other to play with them.
Short shameful confession: I've never set up bridges before. Routers, yes. Switches, yes. Bridges, no. It didn't occur to me that plugging two bridges into the same LAN would cause problems. BAD problems. Problems that made me run screaming around the office, clearing the ARP tables from servers and routers, and briefly causing a few fellow employees and a few thousand customers to lose internet access. DON'T! DO! THAT!
Anyway, I finally had a chance yesterday to try out the Tranzeos in the setting they will be used. One went on the roof of the building we're currently in, and the other went inside the offices we're moving to. I had roof access to the new building, but I wanted to see if they would work with one side indoors to make setup easier. Physical installation was a snap - all needed hardware is included. The all-in-one units support power over ethernet, which also made things MUCH easier.
Never having set up a wireless link before, I was unsure how to most accurately aim the panels on either side. I wound up simply aiming the roof mounted tranceiver by eyesight, and the indoor one using a pair of nice binoculars with crosshairs in the lenses. The units were fired up, and immediately linked at maximum speed. I was floored - I'd fully expected to spend a great deal of time tweaking antenna direction.
I shoved a bunch of data back and forth over the link, and got speeds comparable to a LAN connection. Latency was nice and low as well. They won't be in actual production use for another week or so (delays in finishing our new office space - who would've guessed?), but the initial testing was extremely promising. They're a tad expensive, having cost about U.S. $250.00 each from wirelessguys.com, but the time savings from ease of setup makes the extra money spent well worth it in my opinion. If there's any interest, I'll report how they work under actual network load once the move begins.
JS
