Ok, I have a really complicated problem, so I need the experts:
I've been running a Charter cable modem (3 MB) HSI for 2 years w/o a problem. I was using a d-link router encrypted with 64 bit wep. Well, recently, everything started horribly slowing down. My wireless speeds went from 3mb/s to under 250k. I directly connected the modem to my computer, and it showed 3MB download. So, I assumed the router was the problem. I switched out the D-link for a linksys, but got the exact same problem--wireless connections are ridiculously slow. I tried switching the SSID channel, but it didn't do anything different. I can't figure out for the life of my what the problem is. It seems like the modem is fine. And it's unlikely two different routers have the same problem. Any ideas?
