Showing IP address
Threaded View
Bored and let unused icon cleaner clean desktop.
Had a command or program that placed a shortcut on desktop that would
show your IP address and all other details for networking.
I've forgotten it, can't find it in my XP tips file, so hoping someone
would be kind enough to help me out.
I can do ipconfig for XP but this was something like winipcfg for W98
that would give a neat little window.
Thanks in advance.
Mark
Re: Showing IP address
pheasant wrote:
Never mind.   Found it.  From the Windows 2000 Resource kit at
Microsoft's website.         wntipconfig.exe
On Sun, 01 Jul 2007 12:57:36 -0500, in alt.internet.wireless ,
or a shortcut with commandline ""cmd /c "ipconfig & pause""
Mark McIntyre
Bah.  ipconfig is for wimps.
Real command line junkies (like me) use netsh.  Try:
  Start -> run -> cmd <enter>
  netsh interface ip show
  netsh interface ip show address
  netsh interface ip show dns
There's a bunch of goodies that Vista added to netsh including
wireless diagnostics.  See Section 5:
<http://technet2.microsoft.com/WindowsVista/f/?en/library/3ed3d027-5ae8-4cb0-ade5-0a7c446cd4f71033.mspx
  netsh wlan show
  netsh wlan show all
  netsh wlan show networks MODE=BSSID
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
That might only be helpful for static addresses.
"show address   - Displays IP address configuration."
"Configuration for interface "AR5211-WiFi"
    DHCP enabled:                         Yes
    InterfaceMetric:                      0"
No address is exposed.
Clarence A Dold - Hidden Valley Lake, CA, USA  GPS: 38.8,-122.5
On Mon, 02 Jul 2007 11:13:52 -0700, in alt.internet.wireless , Jeff
.... oops - that means you're running with local admin rights. Yikes.
Pardon me, but thats an oxymoron.....
Mark McIntyre
You might even make the command line
    cmd /c ipconfig | find "IP" & pause
which would display just the IP address(es).
Someone in the lab like some download, maybe from sysinternals, that would
paint a bunch of useful stuff as background wallpaper, but it was static.
If you didn't run it after a change, the display would be misleading.
Some wireless config tools have a systray icon that exposes the IP address
if you hover the cursor over the icon.
On Mon, 2 Jul 2007 18:58:28 +0000 (UTC), in alt.internet.wireless ,
yes, thats nice. Would be good to be able to filter out the IPV6 addys
tho, hm,
ifconfig | grep IP | grep -v "::"
agh, need awk...
Mark McIntyre
grep?  awk?  That doesn't sound like standard Windows to me.
On Tue, 3 Jul 2007 16:11:41 +0000 (UTC), in alt.internet.wireless ,
no sh*t sherlock ?
Mark McIntyre
Not something I use, but this might be it:
http://downloads.zdnet.com/download.aspx?docid=291644
______________________________
Keep the whole world singing . . . .
DanG  (remove the sevens)
dgriff237@7cox.net
Click on the Windows Start button, select Run and type winipcfg.
Site Timeline
