~ Hi ~ ~ When assigning vlans via radius on Cisco Ap1200's is it possible to drop a ~ user into the native vlan the same way you would with a tagged vlan? ~ ~ example :- ~ ~ My ap has several vlans tagged into the ethernet interface lets call them ~ vlan id's 10, 20 and 30. I want to set up the access point so that the ~ native (untagged) is id 40 and assign it via radius in the same way as it ~ would for the others.
Don't see why that shouldn't work.
~ Also I want to manage my access point on a tagged ~ vlan, lets call this id 50.
This you can't do. Cisco Aironet APs must have exactly one IP address, which must be on interface BVI1 (i.e. in bridge-group 1), and bridge-group 1 must be bridged to the native VLAN.
Aaron
