Cisco AP1200 MIBs
May 18, 2006 1 Replies
Hello, is there any list around on useful Cisco Ap 1200 mibs ? In particular which is the mib related to number of clients associated to the access point ? the encryption mode used by clients ecc ecc ? are thre any mibs like that ?
thanks a lot
Rick
Try using the Cisoc MIB locator at
c1200-k9w7-tar.12.3-8.JA
MIBS Supported in this Image Details Download MIB BRIDGE-MIB V1 CISCO-AAA-SERVER-MIB V1 V2 CISCO-CDP-MIB V1 V2 CISCO-CONFIG-COPY-MIB V1 V2 CISCO-CONFIG-MAN-MIB V1 V2 CISCO-DDP-IAPP-MIB V1 V2 CISCO-DOT11-ANTENNA-MIB CISCO-DOT11-ASSOCIATION-MIB V1 V2 CISCO-DOT11-CONTEXT-SERVICES-CLIENT-MIB V1 V2 CISCO-DOT11-CONTEXT-SERVICES-MIB V1 V2 CISCO-DOT11-IF-MIB V1 V2 CISCO-DOT11-LBS-MIB CISCO-DOT11-QOS-MIB CISCO-DOT11-RADIO-DIAGNOSTIC-MIB V1 V2 CISCO-DOT11-SSID-SECURITY-MIB CISCO-DOT11-WIDS-MIB CISCO-ENTITY-ASSET-MIB V1 V2 CISCO-ENTITY-EXT-MIB V1 V2 CISCO-ENTITY-VENDORTYPE-OID-MIB V1 V2 CISCO-FLASH-MIB V1 V2 CISCO-IETF-DOT11-QOS-EXT-MIB V1 V2 CISCO-IF-EXTENSION-MIB V1 V2 CISCO-IMAGE-MIB V1 V2 CISCO-IP-PROTOCOL-FILTER-MIB V1 V2 CISCO-IP-STAT-MIB V1 V2 CISCO-L2-DEV-MONITORING-MIB V1 V2 CISCO-MEMORY-POOL-MIB V1 V2 CISCO-PING-MIB V1 V2 CISCO-PROCESS-MIB V1 V2 CISCO-PRODUCTS-MIB V1 V2 CISCO-SMI V1 V2 CISCO-SYSLOG-EVENT-EXT-MIB V1 V2 CISCO-SYSLOG-MIB V1 V2 CISCO-TBRIDGE-DEV-IF-MIB V1 V2 CISCO-TC V1 V2 CISCO-TCP-MIB V1 V2 CISCO-VLAN-IFTABLE-RELATIONSHIP-MIB V1 V2 CISCO-WDS-IDS-MIB CISCO-WLAN-MAN-MIB CISCO-WLAN-VLAN-MIB V1 V2 ENTITY-MIB V1 V2 ETHERLIKE-MIB V1 V2 IEEE802dot11-MIB V1 V2 IF-MIB V1 V2 IP-FORWARD-MIB V1 V2 OLD-CISCO-CHASSIS-MIB V1 OLD-CISCO-SYSTEM-MIB V1 OLD-CISCO-TS-MIB V1 Q-BRIDGE-MIB V1 V2 RFC1213-MIB V1 SNMP-FRAMEWORK-MIB V1 V2 SNMP-NOTIFICATION-MIB V1 V2 SNMP-PROXY-MIB Note SNMP-TARGET-MIB V1 V2 SNMP-USM-MIB V1 V2 SNMP-VACM-MIB V1 V2 SNMPv2-MIB V1 V2 TCP-MIB V1 V2 UDP-MIB V1 V2
