Newbie Question
Threaded View
yes..i want to make 3 cantennas for my friends...and ISP's Acces point
isnt wep secured..also when i search the available networks i found 2
more Access points and they are also not wep secured...if i build 3
cantennas for my friends, can we ping and see each others files over
network?? one more question...there are some of places that i can
attach my antenna but its minimum 12 meters far...if i use LMR400 is it
ok?? or i need more quality cable?? sorry for my poor english..
thank you very much for all of your answers..
purple
brought to you by http://www.wifi-forum.com /
Re: Newbie Question
If you can establish connections with the AP and it's as wide open as
you describe, you should be able to see each other's machines. Depends
on several things though. For instance, the AP I use has a setting for
turning on or off communications between clients.
12 meters of LMR400 is quite a bit, but there are certainly people using
longer runs of LMR400. If you go to lower loss cable you are looking at
extrememly thick and expensive cable. A more reasonable way to go is to
mount the radio closer to the antenna. Either use a weather proof
enclosure for your radio or use a radio designed for outdoor use. That
way you can run Cat5 with power over ethernet which is far cheaper *and*
doesn't attenuate the signal.
Lastly, if you have an ISP who is trying to provide internet service
under difficult conditions, are you sure your efforts won't be harmful
to their efforts?
Site Timeline
