Hey. I got a new lingsys wrt54gs and it is up and run very fine but one problem !
How to disable Client Lease Time in dhcp menu ? 0= give one day i can not disable the Lease time.
Any :-)
I will have it to stay lockt
Any :-)
On 16 Dec 2004 12:29:23 GMT, spoketh
You can't "disable lease time". If you don't want to use DHCP, then you have to disable the DHCP server. If you want longer lease time, then put in 7200. That's 5 days...
Lars M. Hansen
Ok i get it now.
I use now Firmware_Alchemy-6.0rc4a here can i setup static ip's and they always on always.
Thanks anyway Skibber :-)
