iMac in wireless network
Ik have a PC-based wireless network at home, with a laptop and a desktop PC. I recently bought a pink iMac DV, 440 Mhz PowerPC G3. Indeed, an oldie. How can I attach this iMac to my wireless network? I cannot find a USB-wireless adapter and moreover I read bad news about this solution. Is a bridge the best way to solve my problem?
Klaas Jan Huizing
It should have an internal slot for an AirPort card (NOT an AirPort Extreme). If I remember correctly it also requires a carrier for the card.
Bob W
Bob Wardrope
"Klaas Jan Huizing" wrote in news:4253c0ae$0$44079$ snipped-for-privacy@dreader2.news.tiscali.nl:
I have a slot loading iMac G3. I fitted it with an original Airport card which I bought on eBay. The card needs a separate adapter for installation. The installation is straightforward - there is already an internal anteena fitted to the iMac. It all works just fine.
I have also tested an Ethernet - wireless bridge. This also works just fine, and may be best since:
- Airport cards are quite expensive, and there's also the cost of the adapter
- the Airport only supports WEP (original software 64 bit only, 128 bit with an upgrade) and only a single key
- transpararent Ethernet bridges (often sold as a 'gaming bridge') are quite cheap, or you can also use a multi-mode access point in wirless client mode
I have tested it with the D-Link DWL-810+ and the DWL-900AP+. Both work fine, so I have no doubt that similar products will work as well.
Hope this helps
Richard Perkin
false.
airport supports wpa with osx 10.3/panther with all airport cards. it also supports 128 bit wep, which was added quite a while ago (over 3 years iirc). the upgrade to which you refer for wep is purely software and free. 10.3 is a paid upgrade from earlier versions (and 10.4 is about to be announced so no point in getting 10.3 now).
nospam
nospam wrote in news:070420051649496771% snipped-for-privacy@nospam.invalid:
Indeed. The OP did not say which OS version the iMac is running - I assumed that since he said "Indeed, an oldie" (which you snipped) that it was probably 9.1 or 9.2 and had not been upgraded to 10.n - in which case the available upgrade is to 128 bit WEP. But I could be wrong...
Kind regards
Richard Perkin
I used a LinkSys Bridge Version 2.0 WET11 and it works great with my Blueberry iMAC
cgerlachnospam
Thanks for all your help, the bridge is my solution. KJH
schreef in bericht news: snipped-for-privacy@4ax.com...
Klaas Jan Huizing
