While trying to troubleshoot some router problems, I disabled wireless for my linksys router through the basic setup at 192.168.1.1. Under the Wireless options, there's a radio button for enable and disable. I clicked disable, saved the settings, and now I can't connect to the router through the IP address listed above. I tried resetting the router and still can't connect.
Does anyone have any ideas how I can enable the router again?
