Help with Prolink Router.
Threaded View
Lost the password and I must reset my router. I have some screen shots
of what most of the settings used to be, but probably not everything.
I looked for simplified instructions on what settings I need to change
after the reset in order to get the damn thing working.
But all I found was this Manual which might was well be written in Greek
considering all the techo babble it contains.
http://77pdfs.com/prolink-h5001n-wirelessn-user-manual-pdf
What are the minimum settings I need to make to get the thing running
again.
This is for 3 windows stand alone computers.
After I reset the thing, what default setting are there that I do not
have to bother with and what are the simplest steps to get it up and
running? Any real help, thanks.
Re: Help with Prolink Router.
On Thu, 24 Oct 2019 05:30:53 -0000 (UTC), networkdummy
- What model Prolink router?  Extra credit for the hardware version.
It should be on the serial number sticker.
- What is your internet connection?  (DSL, Cable, dialup, neighbors
wi-fi, WISP, etc).
The minimum is...
LAN side:
   IP address.
   DHCP IP range (probably only needed if you have devices on
   your LAN with static IP addresses).
WAN (internet) side:
   Type of internet connection (DHCP, static, PPPoE, PPPoA, etc)
   ISP authentication:
       Login name
       Login password
WiFi:
   SSID (Wi-Fi login or system name)
   WPA2-TKIP (Wi-Fi pass phrase).
That's about it for most wireless routers.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Thanks for your reply Jeff, you always have the best replies; glad ur
still here for us.
I am not at home so I will have to send the model number later. Only know
that the pix in the url/manual I gave looks identical to the unit.
I have the screenshots about 10 pages of them, much of which I don't
understand but I can see what the settings were before and with your
additional help, go from there, I hope. Will post later what the results
are as I have never done this before.
On Fri, 25 Oct 2019 09:12:43 +0000 (UTC), networkdummy
Y'er welcome.  Glad to be of some assistance.
Well, it's nice to know what you have to work with.
Don't forget about my 2nd question, which is what flavor of ISP are
you using (DSL, cable, wi-fi, satellite, WISP, etc).  This makes a big
difference on the WAN (internet) settings.
Welcome to "Learn by Destroying".  You don't really understand how
something works until after you've destroyed it, and then fixed it.
I'll take a leap of faith and guess(tm) that it's a Prolink 5004n
wireless router.  If so, this should help:
<https://setuprouter.com/router/prolink/h5004n/wifi.htm
It shows the same three pages of settings that I suggested are the
only ones of great importance.  There are a bunch of links to various
Prolink docs near the bottom of the page:
Argh.  I just noticed that I screwed up my previsou message in the
wi-fi section:
That should be:
WiFi:
   WPA2-AES  (Wi-Fi pass phrase).
or if you must:
   WPA2-Mixed  (Wi-Fi pass phrase).
You guessed right. According to the screen shots its a prolink h5004nk
adsl wireless modem
Everyone is using wifi, not dls. It's a wired wifi router with ports for
DSL being unused.
Yeah but I don't own it and I'm not the one paying most of the bill. I'm
just trying to get the pw so I can reboot the rounter from browser which
in the past worked. The modem/router is very flaky and often disallows
DNS lookups requiring a reboot of the router. Don't know why?
Ok, I went through the old screen shots and these are the sections that
look important maybe requiring my input after the reset:
DNS CONFIGURATION
LAN CONFIGURATION
LAN INTERFACE SETUP
LAN PORT
DHCP MODE
COMMIT/REBOOT-COMMIT
CHANGES, RESET,REBOOT
IP QOS
IGMP PROXY CONFIG ENABLED
Funny I don't see in the screenshots a section for setting
encryption/passphrase? What section would that be under?
The sections at the top of the screenshots are: Status,
Setup,Advanced,Service,Firewall,Maintenance,Logout
Thanks again Jeff, ur the BEST!
Site Timeline
