Hi all, I recently got DSL at home and bought a Linksys wrt54G in order to get wireless for my labtop as well as getting a free firewall packaged in.
Anyway, I also have a couple machines on the other side of my room and rather then buy individual wireless cards for all of them, I got a NetGearME102 access piont, which as I understand it can do bridging. What I want to do is setup the NetGear ME102 as a wireless bridge so that I can use it's ethernet port and a hub on the other side of hte room to connect the other computers.
The problem is I can't seem to get it to work -- am I completely off as to weather or not this should be able to work. (I have very little wireless experience -- but I dont see why it wouldnt work) Isn't this exactly what a bridge is supposed to do? Is the problem that one is a linksys and the other is a netgear? Since they both talk the standards I would think brand isn't important.
Anyway, any tips or actually just confirming this should be able to work would be greatly appreciated.
Thanks, ---Brian
