I can't get this printer working wireless, only wired. When I try wireless it just wont use its static ip and subnet etc. I put it in all manually but when I do check status or print a status report it shows all 0.0.0.0. On the wireless network setting it shows the manually configured settings just fine, but on the status tab and the status print it shows "not configured". I configured it via the Web interface.
Anyone has a suggestion or solution?
Greets, Simon
