I currently connect to the internet on my pc using the homehub.
I have recently purchased an Asus Wireless LAN Cardbus Adaptor for another laptop in the house.
When I install the CD onto the laptop, when it is searching for the hub it does find it. However, after putting the key in, it says cannot connect (doesn't give much of a reason).
I have tried setting the connection up manually in Windows too and this does not connect either.
I have double checked the SSID and key to that in the homehub manager and they are correct.
Firewall turned off.
Any suggestions?
