Hi, my "new" house has only one working phone jack, which the DSL modem comes in on. However my network of three PCs is in another room, and stringing an ethernet cable from the LAN switch to the router plugged into the DSL modem is not an option. I also have 2 wireless notebooks. So here's what I'm trying to do. It seems stupid simple, over two weeks and several products, have yet to come close to accomplishing it. Now I'm thinking of ordering two D-Link WAPs that can do WAP, client, PtP, PtMP, and repeater--and give that a shot. But I read on their FAQs that "wireless distribution" mode, they can't to WPA. Anyway, here's basically what I have now:
- One end: DSL modem > Netgear WGR614v5 802.11g router/WAP/switch (switch unused; encryption set to WPA-SPK).
- Other end (which I CANNOT string a wire from): three PCs on an ethernet switch.
- Two more "other" ends: 2 notebooks w/ 802.11b.
The wireless router by the DSL switch, and the ethernet switch creating the PC lan are only about 20 feet apart and within line-of-sight. Right now the notebooks connect to the netgear WAP just fine. Getting the PCs on the ethernet switch connected wirelessly is the tough part. Of course temporarily running an ethernet cable from the switch to the router does work. But for doing it wirelessly, I've tried a gaming adapter plugged into the uplink port of the LAN switch, and more recently a D-Link bridge (DWL-G810). Neither worked. In hindsight it seems unlikely they would with that kind of configuration (pushing traffic from multiple PCs without a NAT router). But I couldn't even get the DWL-G810 to work plugged into just one PC's NIC, while one notebook also worked. (Could get either to work if the other was off, but not both at the same time.) But that isn't really my main problem, since I don't care if that way works or not--just included it in case it's relevant.
The challenge seems to be that I not only want to create a wireless bridge from a router plugged into the DSL modem to a "remote" switched LAN, but also want to connect wireless notebooks to the DSL modem/router. Seems like I'd need a WAP at the DSL modem/router end, the two notebooks, and a bridge on the LAN side--where the bridge and the WAP don't mind traffic from multiple PCs travelling over one wireless connection. (What "mode" would that be?)
It seems like two D-Link WAPs might do it, since they support WAP, PtP, PtMP, client, and repeater mode. Surely one of those might do the trick, no? But their FAQ specifically states that in "wireless distribution mode", (not sure which of the five types that applies to), it doesn't support WPA--which I need because I'm in a very dense high-tech area and have very sensitive data and am very paranoid.
Any ideas on how to bring this all together, and/or anyone actually successfully doing the same thing? I do have a Netgear RT311 router with no wireless and which is more than suitable for firewall tasks, that I could plug the DSL into one side and a WAP into the other (in which case I'd throw my WGR614 away--hate that thing anyway).
One more far less important question: anyone know how adding the extra wireless hop affects online gaming latency? I do gaming on the weekends. Stringing a cable directly for a few hours is feasible, but if the additional lag via 802.11g (or bonded "108mbps" G) is only a few milliseconds, I'd stick with the wireless for good.
BTW, signal strengths are excellent as nothing is very far apart, and I can and may also invest in multiple high-gain antennas.
Thanks, Bob Himes
