Hey, i need some advice if you dont mind. I think the problem is that the signal strength is just not powerful enough, as i can connect to the network when the computer starts but if it drops out then i cant re-connect unless i restart, also im running at 54 mbps (should have a
108 mbps pci) but this can drop to 1mbps, with a signal strength of 30% to 12% (1 to 2 bars on the microsoft bar thing). Im also recieving more than 3 times what im sending.So i was thinking if i upgraded the antenna on the router to something like this; 'Maplin > Compact High Gain Directional Corner Antenna for Wireless Networks'
Any advice or help would be very appericated.
Cheers Phil
