Hi Folks,
At work I've got a 3com 7250 wireless AP which allows for up to 32 SSIDs each with its own individual WPA-PSK key (and each SSID can even be bound to an individual vlan). Obviously its fab for a not so big business network where radius would be overkill but a single shared WPA key wouldn't be adequate.
I was just wondering if there are cheaper APs or also wireless xDsl-modem/routers out there that have the same or very similar functionality? My home budget doesn't stretch to the above mentioned box.
Thanks for any pointers,
Greg
