Hi all - my first post on your forum.
I am hoping the members of this forum can help where other forums have failed. I am getting desperate, so please respond if you have any ideas.
My setup: Apple Mac connected to a 'BT Broadband Hub'
My problem: All works well except that every 70 minutes (to the second) the Soundbridge loses the connection to the music library on the Mac and I have to reboot the Soundbridge to reconnect. However, the Soundbridge is still connected to the network as I don't lose internet radio connection.
Roku say it is an issue with the Belkin, and to be fair if I move the location of the Soundbridge so that it is in range to connect directly to the BT Hub, taking the Belkin out of the equation, all works fine.
Belkin have responded to say it is to do with Port forwarding settings, but won't explain what this means in practice. I have had various other suggestions from the Roku and the Firefly (server software) forums, the most useful to date being that it is likely that the Belkin is changing the encryption key every hour and then 10 mins later dumping the old one. I am using WEP encryption.
I would welcome any help or suggestions on how to identify this problem.
thanks Duff
