A NID, Network Interface Device, is required for all new construction,
> old construction is grandfathered. Here in Verizon land all you need
> to do is call and let them then you need a NID so you are able to
> modify inside wiring.
> If you cannot get satisfaction from the Telco might want to contact
> your state Public Utilities Commission. Explain the situation and see
> what they suggest.
> /tom
Qwest doesn't add them unless the customer pays. I'm under the impression that the telcos are no longer regulated in Iowa.
