I just bought a home with an existing alarm system, ADEMCO, Vista-15 with 2 ADT Safewatch Pro 3000 keypads. I did not have the master code, but was able to find out the installer code. I used this to reset the master code. Things were looking good until I decided to try and make a change, I tried putting an exit delay on the back door. I was not familiar with the programming mode so I messed another zone up. I could not fix the zone, so I reset the programming data by using *97 in programming mode. Things started looking better until I noticed the second keypad was not working. I did a little research and found that by pressing 1 & 3 together I can see the address of the keypads. The one that is working is 16 and the one that is not is 17. I was able to change the address by powering down and then up and hitting 1 & 3 together. I only tried changing the one that was not working. Nothing that I changed it to helped. When I changed it to 16, the same as the working one, the 'ready' light came on but neither keypads worked properly. I assume it's because they are not allowed to have the same address. So, if anyone knows what I need to do to get the second keypad working again, I would appreciate a little advice. The keypads are identical and they were working before I reset the system (*97). Thanks.
- posted
18 years ago
